I get a "Retry" notice when I send a text message
A few days ago my LG k7 phone started showing a "Retry" notice every time I try to send a text message. What is causing this? And how can I fix the problem?
It seems like a networ issue regarding your SIM card, it happens you will have to do is calles a SIM card pull, you disasseble your phone remove the SIM, wait 30 seconds then reassemble. This will help with the network.
このアンサーは役に立ちましたか?
my phone does not have a SIM card it's a LGL34C
l
You either have a problem with your SIM card or your network connection is bad. If neither of these are causing the problem, call a professional.
このアンサーは役に立ちましたか?
You make it sound so simple!
And actually it is, go ahead & call your "profesional", i choose to learn.
Iam check SIM card and network
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 7,507
I have this same problem. What's interesting is the message does get sent.
Kris Sagar さんによる
hello sir..i am same issue like scott sponsler..i text my fiancee with normal texr sms..but all my text become ' RETRY ' after that i try swith off over than 30minit.still same cannot sending..i dont known n no idea ,any solution
Awang Awang さんによる
My android phone is showing a retry message everytime I send a certain person a text message why? And how can this be fixed
Jackie さんによる
Why do I get a retry message when I send a text message to a certain person and how can this be fixed
Jackie さんによる
Why do I keep receiving a retry message when I text a certain person? How can this be fixed
Jackie さんによる
2件以上のコメントを表示
