メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
My controller randomly disconnects
So my Xbox one controller will start flashing then turn off then kick me offline. It does it more frequent than ever right now. I heard something about the wifi card will work and help but I wanted to see if y'all had an answer. How do I fix?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Thank you!!!!
さんによる
I am facing a similar problem. I will be playing a game and my controller will randomly disconnect but the light will stay on. My screen will then state “you need a controller to play this game.” After I take out the batteries and put them back in, it will work for another few minutes. If I don’t use the battery way, the controller will reconnect in about 10 seconds. As you can imagine, this is very aggravating when playing online games. Any suggestions?
さんによる
コメントを追加
2件の回答
ベストアンサー
Yes the WiFi card was my initial thought as i read what you explained. it would certainly be the first thing i would try. if you really wanted to put it to the test, keep your controller plugged in with a USB cable to the console. if your internet disconnects and the controller stays connected i am certain its the WiFi card. its a pretty easy thing to replace thankfully. only mission about it is opening the case
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There us a known issue with xbox ones being in Instant On. I would suggest changing that to Energy Saving and see if it fixes the issue. Mine was doing the same thing til I found that solution. No more problems since.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shawn Lindeborg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 18
今までの合計 4,426
