メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
strange colors on back camera
hey people, i got an iphone 5s with strange colors on the back camera. if i bend the phone it gets worse. doe anyone has experience with this sort of defect? i already tried a different camera .
(picture is a iphone 5 , just for example)
Also i got an 6s with back camera and flashlight problem. when i change the camera nothing happens, when i put a jumper at camera ic the flashlight starts working again but no back camera. anyone got some advice on that one too?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Seems weird i got a 5s too and dont have this problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
can you open your camera? if not follow ifixit rear facing camera guide here
iPhone 5sのリアカメラの交換
on Step 18, dont' remove any of the lcd connector. but touch and try to fix camera cables. (strips). Turn on your phone. and open your camera app (no need to fully reassemble your screen for a while.)
Now when camera is ON, and you can see camera's view on lcd.. try to press camera strips. if you see abrupt behavior of camera... it must be your camera's strips broken.
if nothing changes, remove all LCD connectors from step 18 to 23 following that guide. i mentioned above.
and remove camera's connector.. remove camera out.. try to adjust it's strips from end to end. fix it back.. connect all connectors and check again. if anything change or not...
If it is fine. Thanks GOD or else.. you need to order a new camera for 5s from any online store. I use AliExpress you may use any one.. ebay or some other store.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
hey! thanks for your long answer but i already tried another camera so it must be on the motherboard
さんによる
so.. if this can be fixed you should.. otherwise.. I had blue screen issue with my motherboard. (that mean dead). I ordered one from china (AliExpress) and replaced myself. although that costed me around 100$ but that is still working great.
さんによる
yes okay, thanks for your help
さんによる
コメントを追加
回答を追加する
thieske さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 629
