メインコンテンツにスキップ
The Xiaomi Redmi Note 2 is an Android smartphone sold by Xiaomi, a Chinese multinational electronics company and released in August 2015. The Redmi Note 2 was sold in two variants, the standard and the Prime. The Redmi Note 2 can be identified by model number 2015051.
18回答 すべてを表示
Phone shutting down randomly, unusable.
My Redmi Note 2 is randomly shutting down even when is connected to the charger. This started to happen after the battery swallen up, which was replaced with an original one.
I read online it coud be a rom problem but the is currently running the official global rom and I tryed the official chinese one but the issue persist, TWRP is not installed, fully stock rom.
So this can only be an hardware issue, any thoughts on what is causing the problem?
If I replace the motherboard will it fix the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
this could be alot of issues, the thing i think of when a battery swells up makes the phone unusable is that is could leak form the battery on to the motherboard and make it unusable, so yeah you could try a new motherbord but you never know untill you tested that out..
Update (06/29/2017)
and are you using an original charger?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bruno Goncalves さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,030
