メインコンテンツにスキップ
Blank LCD after replacement
I have two iPads (first gen, wifi) one has black and colored lines/ bars through a portion of the screen, but turns on and responds to touch. The other does not turn on and is not recognized by iTunes, so I presume that the LCD is fine. I switched the LCD's (along with digitizes) and the working iPads screen is now black: no backlight, picture, etc. I can turn it on and can hear the unlock sound when I swipe in the area near the slide to unlock. Many people with this issue seem to have damaged the motherboard, but I believe this is not my issue because I can reconnect the LCD with bars and it does turn on.
I have tried: Both LCD connector cables, powering off before the switch, hard reset (power+home), iTunes reset...
Is there anything else to try or do I have a bad LCD?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
honestly its not worth the trouble, if it is the original ipad, you might want to upgrade to a newer one up to date, i hear most apps wont work on the original ipad anyway
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Christopher さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 26
