メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Is my backlight filter blown?
Well I turned off my phone to fix the selfie camera. before that everything was working fine. But I havent unplugged the battery when i take out my screen i just turn the phone off. After putting the phone back to on the screen stays black. the battery is brand new and the screen is a few months old and i dropped it a couple times my new screen comes tomorrow if it stays black anyone have any ideas what it may be and how to fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Can you see the Apple logo when you are turning the device on while holding a flashlight to it? If so, the it would be your sceeen or the backlight fuse. I would double check to make sure all the connection are tight and not loose or misaligned. If that's all good, I would try a new screen then. This would be a cheaper fix. If the new screen doesn't work, then I would start to look at the motherboard.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
All connections are secure. Black screen even when to into light. will try new screen tomorrow. the phone does get warm as if its on when i hold the power button
さんによる
what could it be on the motherboard if the screen doesnt work?
さんによる
Let me know how the new screen does for you. Have you tested the new battery you purchased to make sure it is all good?
さんによる
the new battery worked fine i got it 5 days ago and it worked with the old screen before it stopped working. i tend to turn my phone off and remove the screen instead of taking out the battery i didnt know i had to do that. I hope its nothing serious. I mean i cant see anything though even under light the screen comes in about an hour so ill let you know
さんによる
It was the screen :) new screen works now
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
dj holley さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 760
