Consoles no longer turning on after swapping internal memory
Hello there,
i have 2 consoles here with me, one of which has a cracked LCD and another that has a parental lock on it. out of curiosity i decided to swap the internal memory chips around to see if the parental lock was bound to the memory chip or one of the other boards. before removing the memory i made sure to disconnect the battery. once everything was all set up and ready to go i tried to turn them back on again to no prevail unfortunately.
any ideas or suggestions to help me here?
thanks!
この質問は役に立ちましたか?
5 件のコメント
slight update, i swapped the memory chips back, the one with the parental lock turns on again but the one with the cracked screen still does no turn on
James さんによる
I'm assuming you made sure the battery was fully connected and charged?
TronicsFix さんによる
you would be assuming correctly :)
James さんによる
Hello James, would you happen to still have one of these systems with you? I'm looking for a replacement part.
zacharywd さんによる
no sorry no longer have it
James さんによる
