Timing chain or timing belt?
Does a Chevrolet Starcraft 91' use timing chain og timing belt?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@erlendodegard,Erlend, Your chevy would have a timing chain. Some chains never need changed unless they exhibit chain noise(conspicuous on a cold engine and does not completely go away when engine warm). If timing check showed that the engine timing was being thrown off by the slack/wear in the chain, more then 5 degrees slack would indicate wear and time to change. Links below will supply more info. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 508
