メインコンテンツにスキップ
モデル番号はA1236で4もしくは8GB容量
134回答 すべてを表示
締切られた回答
pushing on the dial no longer works (ie play/stop)
you can still adjust the volume with the dial, but you cannot press play, stop or forward. You can also dock the ipod nano and still play or stop using the remote, just not on the actual ipod dial.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
While the click wheel is definitely the first part to replace, Apple made it very difficult to do so on these iPods. The click wheel is sandwiched between the front panel and a metal plate that is glued onto the front panel. If you are replacing just the click wheel, you will need some intense adhesive to make sure the metal plate adheres to the front panel. Otherwise, pushing the buttons results in the whole click wheel recessing into the iPod (we've seen this happen with this repair attempt).
Otherwise, replace the front panel with one that includes the click wheel!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It sounds like you will need a new click wheel in order to fix this problem. You can purchase one of theses off of ebay from a US seller for no more than 10 USD.
3rd Gen Click Wheel:
http://cgi.ebay.com/iPod-3rd-Gen-Nano-cl...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 4
過去 30 日: 4
今までの合計 1,658
