メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Screen discoloration in top right corner of iPhone 6 Plus, please help
I replaced the front panel on an iPhone 6 Plus last night. I tested the LCD before installing all of the components (front camera, speakers, home button, etc.) into it, and it seemed to work fine. I even did one more test run before I closed the screen to make sure all of the cables were connected well, and it worked perfectly. When I closed the screen, however, a bright spot had appeared in the top right quarter of the phone. I have had two other 6 pluses with identically shaped and positioned bright spots, so something I am doing wrong must be causing this. Please help me with any information you know.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
It would be helpful if you posted a picture (you can add it to your question).
Generally speaking, white spots are caused by pressure. So if you have a bright spot in the top right corner, look at the camera and screen bracket area for something that isn't installed or lined up properly. It could also be a batch of poor quality screens where there is some dust or something else sandwiched between the LCD and backplate (this would be a very small white spot though).
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I had a white spot also. It was the battery pertruding slightly on the upper left edge (original battery and screen). I solved it by lightly pressing down the edge of the battery with the flat end of a plastic spudger.
さんによる
コメントを追加
i think it has no solution take it to apple authorized centre
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
Garrison Bates さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 6,112
