Why is my coffee maker only making a small amount of coffee
my coffee maker is only spitting out a small amount of coffee even though i press for a regular cup
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Peggy Tilles clogged puncture needle as well as clogged filter could be causing this. Check this guide on how to clean and open it.
このアンサーは役に立ちましたか?
You should have the option somewere to select cup size. Mine has that and it is an early model.
このアンサーは役に立ちましたか?
MaxAwesomeness GB (Max) read the question "even though i press for a regular cup"
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 820
