black screen issue on Samsung 48
model Code UN48H6350AFXZA
NO PIC BLACK SCREEN NO IMAGE
1. Not the main board if it has sound then mainboard is good
2.not power supply,tv is supplying backlights and sound,
3.if panel is bad,you will know by disconnecting ribbon on t-con on one side ... if you have half a image then nothing on the other side your panel is bad... vice versa on the other side!!
4. Answer- NEEDS A T-CON BOARD !!! BECAUSE THE T-CON IS SUPPLYING THE IMAGE!!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 641
Could you please give us everything you know and add some pictures?
iFixitでの質問に画像を追加する方法
George A. さんによる
@cmoody black screen and no sound? Black screen and sound? Have you tried all different inputs? What have you tried? What exact model is it?
oldturkey03 さんによる
