メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Will not charge, no charging light on magsafe?
Hi, I plugged my MacBook into a friends aftermarket power supply, and when i returned home there is no light when plugging it onto a real magsafe charger. Tried using a different charger, resetting SMC.
Also if I plug the magsafe into a different mac and then into mine, the light is orange but slowly goes dimmer until it goes out, and doesn't charge the mac.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I was having that problem. I had several after market power supplies an very slowly my MacBook Pro stopped charging. I would wiggle the MagSafe a little and the amber light would come on the start charging but it got worse and finally I decided to change out the upper case. I SO didn’t want to pull my Mac apart but I finally did.
Do you know what fixed the issue?? A half hour replacement of the MagSafe DC in Board part. I bought a used one off of Ebay for $8 and used the iFixit Guide and it was all better. The amber light came back on with ALL the after market power supplies I owned. I was SO thankful. Try it. You will see
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chris さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 3,271
