メインコンテンツにスキップ
Why is oil coming out around the muffler gasket and the muffler?
I hwve oil pouring out around the muffler gasket and the muffler itself. Replaced the gasket but it's still doing it . The mower will run done for a few seconds then it will blow blue smoke out and die , but will start right back up again. What's my problem ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@danny1974, Danny, Check to make sure you did not overfill the oil/crankcase, make sure oil has not been diluted with fuel(carb. leaking gas into oil) and that proper grade oil used and dip stick secure. The problem could be a blown head gasket,bad valve/guide, crankcase cracked or breather plugged(if equipped), excessively worn piston/rings. Links below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.briggsandstratton.com/na/en_...
https://www.youtube.com/watch?v=bc0gfCds...
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Danny Mitchell さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 41
過去 30 日: 204
今までの合計 15,107
