メインコンテンツにスキップ
Canon製プリンターの修理情報です。
427回答 すべてを表示
Service code reset procedures
i have a S900 that had a Waste Ink Tank error indicated. I replaced the waste ink pads and now I cannot get the eprom to reset. When I turn it on the indicator light goes green then flashes 7 times.
The reset procedure is invloved and I think that may be why I haven't been able to get it reset.
Do you work on this old a printer?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
1件のコメント
I have a MG3520 it had a paper jam now my canon prints badley ive gone thu all the things that Canon told me to try by computer how can I reset the alinement manualy.
さんによる
コメントを追加
2件の回答
ベストアンサー
Here's how to reset it:
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
Service/factory test printout, including ink sensor check
EEPROM info printout
EEPROM initialization
Clear the waste-ink counter
Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
this procedure doesnt work with canon pixma mg2545s
さんによる
I dont have a RESUME button All I have is a POWER,WIFI,PAPER SIZE BLACK,COLOR AND ON AND OFF BUTTONS THAT IS IT.
さんによる
this procedure doesnt work for me. i can set to service mode and thats all....
さんによる
コメントを追加
mine too doesn’t work,
model TS207, any solution?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
R genola さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 39
過去 30 日: 206
今までの合計 49,371
