メインコンテンツにスキップ
The Sennheiser RS 120 is an RF wireless headphone system with open, supra-aural headphones.
52回答 すべてを表示
We get the red light, but not the green light, and we get static
WE do not get green light and just static. Is there anyway I can fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Didn’t mention anything about green light which indicates they’re charged & ready for use,
. Our red light is on for days (with headphones in cradle) but the green light never on.
さんによる
コメントを追加
4件の回答
最も参考になった回答
On the front of the transmitter there is the battery charging indicator light and when the battery is charging this indicator will light up RED. Any time the battery is charging (ie: the headphones are on the charging cradle) this light will be lit RED and it will NOT turn off until the headphones are removed from the charger.
NOTE: The batteries cannot be overcharged because Sennheiser utilizes "trickle charge" technology so that once a battery is charged the charging switches to a lower level to maintain the battery's full charge.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What about the green light? What if the green light comes on at first but after about 5 minutes after I take the headphones off the cradle the green light goes out and the static begins.
さんによる
despite removing from charger , red light is persistently on leading to battery drain????
さんによる
コメントを追加
@kmm ,
Did you try replacing the batteries in case they are failing and not fully recharging?
Even rechargeable batteries have a lifespan
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
May not be a battery or charging issue. Lack of green light could well be problem with audio source connection or setting. ie is audio out turned on via a setting
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I’ve had the HDR 185 for three years. They work well.
But once a year, the red light stays on for weeks.
I fully charged the batteries with a Panasonic BQ-CC17 Eneloop charger. But it’s still red on the Panasonic base.
The last time it happened, it finally turned green one day. So keep using it.
There’s definitely a problem in the circuit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Arlene Berger さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 107
今までの合計 4,744
