メインコンテンツにスキップ
An all-new Passat, based on the Volkswagen Group B5 platform, was launched in 1998 in North America.
42回答 すべてを表示
loosen power and the oil light came on
I have a 02 v6 passat one day driven it .. it started loosen power and the oil light came on ,so I drove it to the mechanic and came back . They said engine was locked up and have to have a new motor, but I can turn motor by hand so I know it's not locked up.. what could it b ?? I've heard of many things read many things anyone who had the problem email me at Jongfella@gmail.com.. thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Jon Jon, If you can now turn the engine over by hand, it does sound like the engine is not locked up. But if the oil pump failed or you ran the engine low of oil and continued driving when oil light came on there could be internal engine damage/wear. Did the first mechanic say whether the engine was low on oil or pump failure or why he felt engine had locked up. If car is not starting and you can not trust what the first mechanic/shop told you, get a 2nd or even 3rd opinion. The shops may have to pull oil pan or use video scope to see/verify what damage's are done and to what extent. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Jon Jon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 71
