メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
645回答 すべてを表示
Blank screen with brightness control, no image
Hi there, I've got a problem with my old, but well treated, Macbook mid 2010 A1342.
So, I had to change the top case, keyboard issues, but everything went well I followed the guide carefully but once everything was mounted I have now a blank screen with no image at all, external monitors and tv's are juste fine, I have brightness controls working but no image. I toke out the HDD reinstalled the OS and nothing, reseting PRAM, and all of the resets possible, nothing works, I tested with other display, same model, and it's the same. Did I "screw" up the logic board?!
I appreciate every kind of comment.
many thanks
I can ad photos if needed.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
If it's driving the external monitor the logic board should be fine. I'd reseat the LDVS cable:
MacBook Unibody Model A1342 Display Data/Camera Cable Replacement
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
Many thanks for your kind answer, before I try this, I would like to say again that I've tried with other A1342 display and I just got the same problem.
A blank screen and external monitor working. If I cringe a bit the display I can see some stripes (left side and right side)
I took some photos:
http://hpics.li/30eea38
http://hpics.li/9e36f92
Do you thing I should do the reseat of the LDVS cable?
Thanks
さんによる
What's showing up on the external monitor?
さんによる
Everything, I pressed cmd and F1 and I can use the laptop as I used to use it.
Everything works fine with external monitor, but with the integrated display I get the blank screen as we can see in the pictures, any thoughts?
さんによる
I would examine the LDVS port on the logic board, see if anything is amiss. Also the cable and make sure it is fully seated.
さんによる
i will try everything you said and come back with the results.
many thanks Mayer
さんによる
3件以上のコメントを表示
コメントを追加
It might be that something went wrong somewhere during the repair and you got something along the backlight circuit shorted. You should start with testing the backlight fuse for continuity. It's the part number F9800 on your board..with a little googling you should be able to find the necessary references to locate it.
It's on the bottom side of the board, quite near the magsafe connector. Sorry but I don't have any board like yours at hand to take a pic.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
https://postimg.org/image/uqxa4o25r/
I juste took a look and they are fine.. backlight its ok.. I can control the brightness with no problem, the screen goes darker or brighter as normal but always with a blank (white) screen..
さんによる
At this point it sounds like @mayer solution is the only reasonable one left, a bad display after another.
さんによる
コメントを追加
回答を追加する
Bruno Pereira さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 103
