IPAD Storage space increase
Hi there.
Where is the storage for the IPADs? How can I increase the chip and put in more storage space?
この質問は役に立ちましたか?
Hi there.
この質問は役に立ちましたか?
You can not directly upgrade storage for any iPad generation. Upgrading the storage would require an external sd card but the iPad memory is only internal. Here might be the solution for you. It's an adapter for SD cards http://www.crunchgear.com/2010/01/27/app... Good luck.
このアンサーは役に立ちましたか?
Another solution to this is using the new Goflex Sattelite wireless hard drive by seagate.
http://www.seagate.com/www/en-us/product...
500GB of extra space ;)
このアンサーは役に立ちましたか?
Wireless drives are expensive. A cheaper solution is to store your videos and photos on an SD card with a special folder structure. With a connection kit these can then be transferred directly to and from your iPad. See http://www.ipaddvdtransfer.co.uk/ for more info.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 10
過去 30 日: 13
今までの合計 12,621
