メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
No image on any screen after correctly replacing 5 SE LCD
Hello!
Today I replaced a customer's LCD on their iPhone SE. After disconnecting the battery, the phone may have been on when the battery was disconnected, then removing the LCD (note, the LCD was not removed while the battery was connected), I have been unable to get any image whatsoever on the screen.
I've tested 5 total screens, original good LCD included, all of which display nothing after the phone was disassembled. The phone has been restored in DFU mode to no avail.
This does not seem to be a backlight issue as absolutely nothing is visible on the screen under any circumstance. Shining my iPhone 7+ flashlight at the screen from all angles results in nothing more than a black plane. I've tested every possible thing I can think of and am left with a brick of a customer's device.. Any clues on how I could proceed?
Thank you,
Dan
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Did it work before the replacement?
さんによる
It worked perfectly before the replacement.
さんによる
コメントを追加
2件の回答
ベストアンサー
You've tried a new battery? And a new Lightning dock? And when I say new I mean known good? If that doesn't take, I would shoot for the u2ic. Also, are you sure these parts are for SE? Cause if they're for 5S, it's not gonna have the same effect
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This has happened to me before and all I had to do was disconnect the battery and hold the power button down for 30 seconds. Then reassemble. Hope it works for you too!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Sadly, this was tried before and after your comment to no avail. :(
さんによる
コメントを追加
回答を追加する
Daniel Ruess さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 470
