メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1364回答 すべてを表示
Repair or Replace NFC antenna
Hi all,
Wonder if anyone can help. My OH, left her lovely iPhone 7 plus on the car roof and drove off. The inevitable happened, it fell off and then crushed by a truck (found by find my iPhone).
Amazingly a new Display unit and the phone turned straight on. However on replacing the housing, we seem to have lost the wifi and NFC. On closer inspection where the Wifi antenna (at the top) connected to the Antenna band its ripped away and where the NFC connects to the top right of the Logic Board that has ripped away also. I've found a replacement Wifi Antenna, however I'm unable to find the NFC. Are these linked to the phone individually?
So really two question, with hopefully one answer.
1. Can you get a replacement NFC antenna?
2. Could what I have left, be soldered to the ring on the board directly?
Thanks
Andy
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Just worked this out, this is for iPhone 6, however iPhone 6 plus should be similar.
The NFC antenna is the top bezel itself, the top bezel has 2.4G(wifi and Bluetooth), cellular diversity, GPS and NFC. The
main feed point for GPS, cellular and 2.4G is the screw boss under the plastic add-on antenna, with a "grounding
bracket" attaching it to the bezel. The plastic antenna serves as the 5G wifi antenna.
The NFC antenna feed point is the screw boss next to the camera and sleep/wake button, with a flex cable under the
camera bracket serving as signal conductor.
There is an additional feed point in the middle of the bracket, it does not connect to any wireless services, however it
connects to a dynamic switch to tune the top bezel dynamically to serve different bands.
The F-shaped flex cable on the back of the board is JUST a bridging cable, not an antenna in any way.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Would this be the same for the iP7?
さんによる
コメントを追加
回答を追加する
Andy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 4,885
