メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年10月16日に発売された iPad Air 2は初代 iPad Airの継続版でより薄くなったスタイルです。
Home button no longer working
Hello all, I was fitting an original iPad Air 2 screen and forgot to seperate the battery from the main board. A tiny static spark occured when plugging in one of the ribbon cables now the home button does not fuction at all.
I put the home button back in the orginal broken screen and it works fine. I have tried three diffrent home buttons and none will now work in this screen.
Is there some sort of IC chip in the digitliser?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
That connector is responsible for the display and home button. The connector pins are directly connected to tiny passive components (capacitors, filters etc.) right next to the connector under the surrounding flexible shield.
When you inserted the connector under charge, it was probably misaligned and shorted out voltage carrying pins, which most likely blew some of the filters. If you're lucky, the damage will be limited to the filters. The short circuit could also have caused damage upstream in the circuit.
This will require a micro-soldering repair and is not a DIY fix.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You probably shorted something out. When doing repairs, it's important to disconnect the battery beforehand. Since you said the button worked on the broken screen, you probably have the incorrect replacement part.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 433
