メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
E101- What is the cause and how to fix
Bought an Xbox one on ebay advertised as having E101/E102. Displays E102, then after either the offline update or the factory reset USB it displays E101. Upon restart it goes back to E102. I've tried both of the tools, but every time it says something went wrong. The first time I tried the the update tool it hung at 5%, so I shut it down and retried. Then it would immediately say something went wrong. When I try the factory reset option, it reboots and then says something went wrong. It's still got the warranty sticker, and I plan to resell it, so opening it up to reformat the hard drive isn't prefered. Also, should I have too, is reformatting the HDD all that's necessary to installing the OS? Does it install it from the internet? Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
@tronicsfix help, please!
King of Consoles :-)
さんによる
コメントを追加
1 件の回答
ベストアンサー
It's that the update partition on your hard drive is corrupted. You can use the Xbox diagnostics tool (I don't remember the exact name, it can be found on Xbox's page, though), or fix the update partition by disassembling the Xbox and plugging the hard drive into a pc and following a guide on se7ensins. Your last options would be to send it in to Microsoft or sell it.
Hope this helped!
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I know I can fix it by de-corupting the HDD (I did that on my own with E200) but it still has a warranty sticker, so I'd prefer not to open it. Is there any way to do it externaly?
さんによる
Thanks. Turned out my HDD is all messed up.
さんによる
I find nicht se7ensins guide. Link?
Thanks ;)
さんによる
Link please for the se7ensins guide
さんによる
コメントを追加
回答を追加する
George A. さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 14
過去 30 日: 67
今までの合計 15,374
