Can I turn off the startup sound
Is there any way to turn off the VERY ANNOYING AND LOUD startup sound? I absolutely hate it so much that I will sell this speaker if I can't get rid of that noise!
It's not easy to see, but the answer is on this page as a comment written by @nalegke, so I thought I'd repost it as an answer.
"Download the JBL Connect mobile app, update speaker's firmware and turn off the alert sounds from the app."
Just confirmed this for myself.
このアンサーは役に立ちましたか?
works. thank god and thank you to the poster
Wondeful! Thank you!
I can’t find the option to update firmware in JBL Connect app to disable the startup sound of my Flip 4. How do I update the firmware?
Great! it was driving my wife mad - me not so much. The firmware update worked perfectly. Thanks.
The firmware update you're talking about is the Connect+ update? And is it also working for the Charge 3?
このアンサーは役に立ちましたか?
MeToo :-(
Under the Info I can see Firmware Version 3.2.0 . Is this already the most up to date?
I can only see the options for the "stereo" mode, the "party" mode as well as the 'voice assistant'. Where are there any others (FW update, turn off the alert sound ...?)
Hans, I see same. No icon for updating over speaker image either.
To my knowledge Flip 4 doesn't have the possibility yet (8.10.2018) to turn off the startup /shutdown sounds. :(((
I have hacked it, and it is possible to disable any specific sound. The procedure is quite dangerous.
Initially I wanted to publish it here on ifixit, but then decided to stay underground, in hopes CSR/Qualcomm won't bother to take down their leaked tools.
So instructions here: https://hackaday.io/project/162337/instr...
thanks a lot Victor, I finally escaped from those awful sounds.
For Flip 4 the customer support answer is:
Drin at Customer Service
· 2 years ago
Unfortunately, the notification sound can't be adjusted. These are fixed feature settings which cannot be changed
so not much you can do now - this is annoying ….
このアンサーは役に立ちましたか?
I have downloaded the JBL Connect app (Samsung S7), upgraded to JBL Connect+. Does nothing, except change name of the JBL Charge 3 and do upgrade again.
How can I access the “turn off alert sounds” ?????
BTW: the app stays most of the time in “Discovering” mode (although BT works fine).
Please help
このアンサーは役に立ちましたか?
Can’t find a way to access the firmware upgrade (how can i know what my Flip 4 has? Only party and stereo show up in the app. Ideas?
The app only supports a handful of speakers. The Charge Essential is not supported. The On/Off sound is so annoying that my wife forbids me to use the loudspeaker if she is around.
So, for this model, the only way to get rid of these blasting chimes is to not buy it in the first place… JBL confirms that this, indeed, is the only solution.
このアンサーは役に立ちましたか?
Unbelievable. How to ruin a perfectly good product with glorious dumbness.
Yes i also hate that loudly sound of startup. In there anybody know how to turn it off?
このアンサーは役に立ちましたか?
It's the JBL Connect app on android. First install the app / update it to the newest version via the play store. edit: this is the app https://play.google.com/store/apps/detai...
Connect your phone via bluetooth with the box. If the app then prompts you to do a firmware update, plug the box in an outlet to charge and do that, this takes a while.
When everything is up to date you should see your box on the main screen of the app like here https://imgur.com/LaUcEkL.jpg
if you don't see that try to restart the app, and make sure your phone is still connected to the box.
Then tap on the grey gear on the bottom, and disable the option "audio feedback sounds".
This worked for my charge 3, hopefully it's the same for your version. If you have iOS it should be similar, but I don't know the exact details... I hope this helps :)
IT WORKSç Thank yu JH
このアンサーは役に立ちましたか?
Effectivement pour la JBL Charge Essential, JBL que j’ai contacté confirme que le firmware ne peut pas être mis à jour et les bruits horribles au démarrage ne peuvent pas être supprimés sur ce modèle.
このアンサーは役に立ちましたか?
those using iOS should download JBL Portable from AppStore then connect their phone to the speaker via Bluetooth then connect the speaker to power source then option to upgrade firmware (the whole process is 3-6 minutes) will appear after upgrading it then look for feedback tone then turn it off. Enjoy your speakers
このアンサーは役に立ちましたか?
Sorry, that does’t work. Flip series just doesn’t connect to the %#*@ App.
Solved the issue in 2 sec. Download the JBL portable (IOS). On first page you find the button to remove the sound.
このアンサーは役に立ちましたか?
Thank s, Thomas.
However, the question is: is the model _Charge Essential_ listed as a supported model in the app?
THAT is the problem.
If you take the time to read this thread you'll see that your "solution" has already been posted many times.
But JBL only includes a handful of its models in the app.
For example, see Gerard Achat post of Feb 28, 2022 about this issue.
What we're trying to do is put enough pressure on JBL to either fix this issue in the app, or not add these noises in models that cannot be managed.
Any post that says that this has been solved reduces the chances that JBL will take any responsability for what is a big, big, big design flaw.
All you've to do is right-click on the Sound settings in the bottom-right corner of your Windows system tray, and select Sounds. The Sound settings dialog box will be launched. From there, uncheck the Play Windows Startup Sound checkbox, and click on OK.
Regards,
Peter
このアンサーは役に立ちましたか?
The original question refers to the sounds that JBL speakers make when turned on, turned off, Bluetooth pairing, etc.
It is not related to Windows sounds.
過去 24時間: 44
過去 7 日: 362
過去 30 日: 1,813
今までの合計 106,456
24 件のコメント
I also hate that loudly sound, is there anybody can help me how to turn off that sound? Tks
Adang isnandar さんによる
I'm also having a very hard time turning off that sound. The sound prevents me turning on my speaker at night.
jobs4jen さんによる
You can turn it off. Update the firmware using the JBL app op your phone. Then you will find an option to turn off the start-up sound.
Lilecama さんによる
Could you please send a picture of this app. I have installed and uninstalled 5 different apps, as some don't work, where other ones I can't find the firmware update
jobs4jen さんによる
J H さんによる
19件以上のコメントを表示
