メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
Battery Replacement from "OEM replacement"
I recently replaced an old battery that had well over 1200 power cycles on it. I came upon finding an "OEM" replacement on Amazon and purchased it. After installation the battery showed 50% charged which I hear Apple does do their batteries, so I figured it was authentic.
After doing a complete charge and drain for battery calibration, the attached image shows something odd... It seems like it already had lost 7.8% of it's Design Capacity but charged above 100%...
Another thing I had noticed was that under the Battery Info... it shows that there is a battery failure.
What should I do? Any help would be much appreciated! Thank you.
== Screenshots: ==
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The Mac hardware itself is pretty accurate when it comes to discovering issues with the battery . If there really is an error, I suggest trying to get your money back on Amazon.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I'm currently in the process of doing another drain and charge calibration. I might do this a couple more times just to make sure. But your input was very helpful. Thanks!
さんによる
Battery drain won't help in this case.
You need to reset the SMC and zap the PRAM.
さんによる
コメントを追加
These types of batteries actouly to the oposite effect when you fully discharge it especially the first few times kills your battery as you said about 7% or more.. making the batery last shorter with less cycles before fully killing it from 400 to 600 cycles about. I forgot the corect termenology but look at it as killing the battery cells by draining it has nothing to suport the cells making the few on top die. Suggestion is always keep it charged beetween 25 to85% battery charge fir good health.
Engineering Soiderman
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
iWolfram さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 271
