Can I repair it if it fell in water
I had a protection case around it the water got in through the ports on bottom can it be repaired it charges but no screen images black and gray
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@ychi I suggest you treat it just like any other water damaged device. The very first thing you want to do is to not try to restart, sync or otherwise use the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using this video. Remove all EMI shields from the motherboard. Then clean it with +90% isopropyl alcohol. Follow this guide , and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 8
今までの合計 1,916
