メインコンテンツにスキップ
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
50回答 すべてを表示
radio is stuck on am
ok i recently had to replace my battery in my 2008 ford-escape my radio was working fine before i changed the. battery i put the. ew battery in and now my radio is stuck on am and none of the buttons will work i've tried pulling the fuse i've took the unit out and blew it out i even put the same head unit out of another ford escape and it still did the same thing idk what else to do
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Replace face plate it's a control board. Mine got wet from sunroof being left open. I got one from ebay 26 bucks
さんによる
コメントを追加
1 件の回答
ベストアンサー
@kyle1203, kyle, Try a reset, disconnect the negative battery cable overnight or for at least 8 hours. Hopefully works after this reset, if it does not could mean you have a part failure/internal board faulty. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
do you know what part it would. e that would be out
さんによる
kyle nichols, Thanks for replying back, I do not know which part could be bad, the radio would have to be disassembled and board/components tested to find fault if need be. May not be cost effective to have radio repaired unless able to repair yourself as good used radio possibly under $100.00 through a search or auto recycler. Good luck with your radio.
さんによる
コメントを追加
回答を追加する
kyle nichols さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 38
今までの合計 5,955
