メインコンテンツにスキップ
Repair information and guides for saws, including circular saws, jigsaws, and scroller saws.
Why is it losing power? Where to buy parts?
Craftsman Model 315.172110 jig saw, it's losing power. I ASSUME the brushes need to be replaced. Not having much luck finding replacement brushes online. Anyone know, first, if this is the issue and second, where I can find a brush kit?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Dan Krier describe the "it's losing power" situation a bit better. If the brushes are worn then the jigsaw will not work. Not working means absolutely nothing working.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Dan Krier, I had the same result as you after doing a good search brushes discontinued and no alternative part listed. If need be, in the past I was able to order similar brush to what I required in a old saw(new brush was a little wider) so all I did was sand it down a bit to fit, reused old holder/spring and it worked very well. Below is a sample of brushes that are available for power tools. etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.amazon.ca/s/?ie=UTF8&keyword...
http://ohiocarbon.com/products/power-too...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Dan Krier さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 115
