Replacing the handle on the microwave
I need to replace the handle on my microwave, it is broken where the bottom screw is attached to the door.
Thanks.
この質問は役に立ちましたか?
Thanks.
この質問は役に立ちましたか?
Generally speaking I don't recommend user repair of microwave units. In the case of a door lock repair you should have a microwave leakage tester to make sure the seal is correct or you risk blindness. As I say this is one of the few cases where I recommend professional repair or replacement.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 5
今までの合計 1,759
