メインコンテンツにスキップ
The Kenmore Direct Drive is a washing machine by Kenmore.
Why is my washer making a scraping noise when it agitates?
Washer was working great until we moved, and now ever since then it makes that noise when it is in the agitates? We did not lay it on it's side, we used a dolly to move it to it's new location. I really need the help to fix! Everything else runs fine spins great and filled fine, just happens when it washes the clothes.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
9 件のコメント
had sears repair over today on same problem. ordered belt, cap and bearing going to run $200 to fix. its a maytag thats 8 yrs old and only used 2x per week so motor has a lot of life in it. i'm getting it fixed by sears.
priced new washers today on line and at Home Depot. with tax and delivery/set up running $400. a fix is a bargain. btw i called maytag and they wanted $400 to replace belt.
さんによる
I had this problem, and chased it for a while. The drive pulley nut was too tight, causing this noise (my fault, I had been working on the machine). I backed off a quarter turn, and it's running fine now.
さんによる
Can anyone tell me what will make a washing machine just stop aguteating and spinning all at once?
さんによる
My Admiral mod#Atw4675yq1 is making a grinding like noise in Washington cycle.
Just started all of a sudden.
さんによる
Sorry in wash cycle.
さんによる
4件以上のコメントを表示
コメントを追加
6件の回答
ベストアンサー
It could be the pump bearing. Tilt the washer back. Look underneath and take the belt off. The pulley on the pump is metal. try turning with your hand both ways. If it grinds that is problem.Sometimes something works it's way into the pump assembly, this will make a clicking or scraping noise. When the motor drive coupler starts to wear down, the washer may also become noisy. Also make sure that there is nothing between the agitator and the tub that could cause it to grind. Make sure your washer is leveled. http://www.justanswer.com/appliance/42wc... mayhelp you as well as http://www.applianceaid.com/direct.html good luck
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
I had a scraping noise like an old swing chain - it was the top bushing on the suspension rods!- I pulled the front panel- removed the top a little to access the white plastic bushing and used Vaseline in back and a spray lube on the 2 fronts - magic- ps the video on u tube was right on for taking the machine apart - watch it first
さんによる
コメントを追加
最も参考になった回答
I had the same problem after I moved. I found out the cause was when I used a hand truck to move the machine it pushed the thin metal bottom of the machine up just enough to to contact the moving parts making a metal on metal grinding noise. I took the front panel off and pushed the metal back down- problem solved.
このアンサーは役に立ちましたか?
スコア 16
15 件のコメント:
Thanks Rene. I had the same issue with my 1 year old GE Hydrowave upright HE washer and we came across this blog and decided to try your solution first after we just moved and had the Sam issue with a scraping noise when the agitator was active. It worked! The bottom was buckeled a little bit and my hubby took the bottom off and pushed it into shape. So far, so good. No more scraping. Thanks!
さんによる
You just saved me over $100 in repairs. The bottom was buckled, so far so good! Thank you!
さんによる
Thank you so much!!!!! Mine is brand new and was making that metal to metal scraping sound during agitation. And it was from the dent on the bottom plate cause by the hand truck! I am thankful for your advice!!! I don't know why they make the bottom plate so flimsy?!
さんによる
Same for me...hand truck dented the metal pan. Quick pry with a screwdriver and popped out the dent and no problems.
さんによる
My Machine wasn't moved it just started making this noise out of the blue. Any thought? Could it be the same thing?
さんによる
10件以上のコメントを表示
コメントを追加
There is a plastic cap on top of your agitator inside there are plastic "dawgs" that are rigid like a gear which grips the shaft when agitating. anyway they may have been bumped loose.there should be three or four in there. use one of those links that old turkey put in his reply to show you how to replace them.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
My lightly used washer was making a noise when the agitator was running, too. I put on a new belt, no help. Then I decided to remove the agitator. I pulled off the softener cup holder, and the bolt holding the agitator was buried in old softener junk. I pushed the socket into it, removed the bolt, and then the agitator. After flushing the agitator a lot in hot water, I turned it upside down and more gunk came out of the bottom. After cleaning for 20 minutes, no more gunk. Reinstalled the agitator, and it fixed the noise! I never could get the agitator apart, but evidently the gunk built up inside the gear and cog system, causing the noise. And the softener will work a lot better too!
さんによる
What that problem causing your clothes to get tangled up when trying to wash? I'm having the same problem also
さんによる
コメントを追加
direct drive, no belt or pulley.
go to sears parts with mo no and see breakdown.
worked on plenty of them. cant think what it would be.
Update
'''direct drive, no belt or pulley.
worked on plenty of them. cant think what it would be.'''
THE WHOLE SKIN/OUTER CABINET COMES OFF TO WORK ON IT AND
TO SEE THE MECHANISM. START BY REMOVING 2 SCREWS THAT HOLD
CONTROL PANEL ON -- ONE ON EA END. LOOK AT BREAKDOWN!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
See if your insurance company can pay and you pay excess
Sometimes excess is same or Close to the repair cost
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
We had the same problem moving with dolly. We got great advice. We took off the front panal, banged it down with hammer, problem solved!!! Thank you so much!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kristin Albertson さん、ありがとうございました!
統計データ:
過去 24時間: 18
過去 7 日: 158
過去 30 日: 751
今までの合計 260,185
