Why does my scooter quit running when I apply weight to the seat?
Starts and runs fine, just when I take off the kickstand, and put weight on the seat it just dies
@theshadows sounds like either a torque issue or you are cutting something off under the seat. Check first to ensure that the fuel line is not being 'pinched' or that it pulls on some wires.
If it idles okay but does not have any torque you do want to check the compression and see if your engine performs as it should. I'd also would try to adjust the carb. You want to start with the air/fuel mixture screw first. Also check your float height and make sure that the level is right and that the needle valve is not stuck.
このアンサーは役に立ちましたか?
Kill switch wiring reversed?
I found out.that my ht lead was split.everytime i sat on the bike it was shorting out the spark when it touched the top of the
このアンサーは役に立ちましたか?
Thank you Neil, your answer was useful. I found out a malfunctioning ignition coil and replaced it. Now the bike is perfectly alright. I feel this kind of problems are due to faults in electrical connection.
Did you check your battery connections. Sounds like your issue might be an issue. From my understanding, you do need a good battery connection for the bike to run.
このアンサーは役に立ちましたか?
My 49cc 4stroke scooter shuts off when I shake it back n forth. Where is short?
you cvt is messed up. if it dies when you stop and then it's hard to push, your cvt has something wrong with it. clutch is stuck or something in there.
このアンサーは役に立ちましたか?
過去 24時間: 6
過去 7 日: 31
過去 30 日: 82
今までの合計 7,615
4 件のコメント
I have the same issue.ut runs fine on the stand..starts first time..it will keep running with me walking next to it with the throttle open at walking pace.also run with me on it while in centre stand..but as soon as I drop it of stand with me on it it cuts out instantly
Neil さんによる
Even I have the same problem. Mine is a Honda Dio 50cc (Japanese). Starts, accelerates everything fine but when I release the central stand and when the rear tire touches the ground bike shuts down. All the battery connections throughly checked. How to fix it?
White Blossom さんによる
mine will run fine on the stand and when i take if off it slows down and speeds up very slowly and sometimes will cut out and i have tried so much but cant find out i am 15 so i cant legally drive a car yet if any knows whats wrong that would be grate
Chayton Barr さんによる
I faced the same problem with my hero pleasure.
BISWARUP GHOSH さんによる
