メインコンテンツにスキップ
Advanced Bluetooth enabled speaker that is compatible with all Bluetooth enabled devices, such as smartphones and music players. Manufactured by The Wand Company, it was released at San Diego Comic-Con in July 2015.
How / where can I get a replacement battery?
My Communicator was left on display on it's unplugged charging base for about 7 or 8 months. The unit would not power up and when I plugged in the charger to charge the unit, the light does not strobe from yellow to red when the Communicator is placed on the charger, but stays strobing blue to green.
Does this mean my battery is damaged and can no longer be charged?
And if so, how or where can I purchase a replacement battery
Thanks....
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
ベストアンサー
They are actually on eBay. https://www.ebay.com/itm/186054542706
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@misterm86164 I just added the image of the battery. This is done in case the link should becomes invalid over the next few years. That way people still know what battery they will need for this device. Great job on providing a final answer on a 6 1/2 year old question!
さんによる
コメントを追加
I contacted the Wand Company for the same reason. Seems that when the battery flat lines, some defecting charging bases cannot jump start the charge. The Wand Company is sending me a replacement charging base at no cost. Once the battery is charged, I can use my old charging base as a backup. You can also remove the battery and charge it using a cable and correct charger. Once it has some power, you can again use the charging base to fully charge the battery but do not let the battery to completely discharge from that point.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi, I have a similar issue that the battery wont charge, unfortunately I let it run down without charging it over a long period of time. Do you know if the "jump start" method would work and if so how did you do it?
さんによる
Is there an alternate magnetic charger that comes with a stand to charge the communicator without the original stand?
さんによる
@paulstanle98763 Did anyone find a charger that would work? I have a battery customer looking for one.
さんによる
コメントを追加
Bought mine on Ebay they work great
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
HI, I have a similar issue, can you post the link to the ebay site please so I can have a look and buy one.
Thanks
さんによる
コメントを追加
I have them if you need. Been selling them for year. I have contact with The Wand Company.
THE WAND COMPANY Star Trek COMMUNICATOR BATTERY 382527 NEW
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
czero さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 50
今までの合計 1,749
