メインコンテンツにスキップ
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
557回答 すべてを表示
Riding mower emits blue smoke
Sears riding mower emits blue/white smoke starting two days ago. Added Lucas oil leak additive after using Lucas engine clean and still smokes. I had Sears tune up last summer with new oil, air, fuel filter and oil change. Is this worth trying to repair?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
@chuckypoo, Charles, If your sears mower was equipped with the Briggs and Stratton eng., may have a failed head gasket as it seem's to be a often occurrence. If mower is still in good condition it would be well worth having diagnosed, especially if it was only needing head gasket or even simpler repair.
Blue or white smoke coming from your engine usually indicates burning oil, which can be caused by:
-Overfilling the crankcase with oil
-Incorrect oil grades
-Operating engine at greater than a 15 degree angle
-Inoperative crankcase breather
-Crankcase air leak
-Blown head gasket
-Worn cylinder and/or rings
Links below may help trouble shooting and repair of head gasket. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.briggsandstratton.com/na/en_...
https://www.youtube.com/watch?v=aO_m-2z-...
https://www.youtube.com/watch?v=NM28FSoU...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
-Crankcase air leak
-Blown head gasket
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Well this post is about cars, but I'm pretty sure it applies: https://www.emissions.org/types-exhaust-...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Charles Willis さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 72
今までの合計 11,727
