メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
no sound from right speaker and poor sound from left speaker
My right speaker is not putting out sound. The left speaker is working but sounds very tinny. I am guessing the subwoofer is not working either as the sound is so thin. I tried replacing right and left speakers and the subwoofer, but everything is the same. The connections all seemed to be secure.
I don't think it is a software issue. I have tried many things including resetting the SMC and PRAM. The problem is the same whether I boot into OS 10.6.8 or OS 11.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
The connection of the right speaker is quite tight and tricky. In my experience it can sometimes disconnect when reseating the logic board. All in all, the acoustic performance of this speaker system is lacklustre. It's a fact. I use Bongiovi DPS system wide audio post-processing software to slightly enhance that poor performance. It works well. https://bongiovidps.com There are other alternatives in this space, but I found this working best for me. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I tried out Bongiovi DPS. It raises the volume and seems to boost the high end, but still sounds blown out.
さんによる
In the settings panel, there is an option to disable volume boost. Try the different profiles. I found "MacBook Turbo" working for me best.
さんによる
コメントを追加
回答を追加する
gaijin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 288
