MacBook Pro 15'' late 2011, not turning on, SIL blinks every 5 seconds
I posted this on apple discussions, but I thought I would try it here as well.
I have a MacBook Pro 15'' Late 2011, i7 processor. When ever I plug in the power cord (without pressing the power button), the sleep light turns on, turns off, waits 5 seconds, then repeats, the fans follow along with this cycle. It does the exact same regardless of whether RAM is installed, or not installed. NOTHING else turns on, other than the sleep light, and fans. It does this even if the screen is closed.
When the power cord is disconnected, you can turn it on pressing the power button, however, the sleep light does not turn on, only the fans. The fans turn on, then off, wait five seconds, turns on, turns off, then repeats.
What we have tried.
- SMC reset
- Removing RAM
- Changing RAM
- Using only one RAM slot
- Trying to turn it on with no RAM
- With hard drive
- Without hard drive
- With a different hard drives.
- Attempted PRAM reset
Not exactly sure what to do now. Any help or suggestions are appreciated.
この質問は役に立ちましたか?
4 件のコメント
What's the history of the machine? Did you ever get screen anomalies?
mayer さんによる
Sadly I do not know. I received this computer from a computer charity the other day as is. So all I know about this computer is that it does not turn on.
Peter さんによる
Not much to go here. Press the battery test button on the side and tell us your findings. What does the mag-safe light do when you plug it in?
mayer さんによる
When I press the battery test button, it acts as normal and turns on the green lights displaying the battery charge.
When plugged in, the mag-safe light turns green, then after a few seconds turns to orange.
Peter さんによる
