メインコンテンツにスキップ
Can I upgrade to Windows 10
I've got a HP Pavilion dv7 laptop that has Windows Vista OS. I wanted to find out if I can load Windows 10 onto it. General Google search says Windows 10 needs:
1 GHz or faster processor,
Ram: 2 GB (64bit)
16 GB free hard disk space
MS DirectX 9 Graphics device with WDDM driver
This laptop has:
Processor: AMD Turion X2 Dual-Core Mobile RM-70 2.00GHz
Ram: 4 GB (64bit OS)
and once I clear old stuff off would have plenty of hard disk space.
It appears to meet the specs (but i'm not a technical person) and the one thing I'm not sure about is the Graphics card. It's a ATI Radeon HD 3200 Graphics, which I read elsewhere (another general google search) that it is supposed to work but may not work for Windows 10.
If anyone has more specific information I would really appreciate it. This Laptop is in great shape, has a larger screen than my new one, so I would like to keep it.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Slow boot solved
by disabling the display driver for the Radeon graphics card leaving only the intel one enabled I reduced the windows 10 start up /boot time to around 20 seconds from a previous 1m47s. It seems 2 display drivers at once conflict. I changed the drive to an SSD. Word etc now loads instantaneously. It's now a great machine
さんによる
コメントを追加
4件の回答
ベストアンサー
Yes, you can upgrade. It will actually work better than Vista. However, you do have to purchase a license.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Get a legal copy of Windows 7 64bit version. Should be lots around for free or very cheap. Then upgrade to Windows 10 for free from Microsoft website.
I've got Windows 10 running fine on an old system with an AMD ATI Radeon HD 3200 graphics card.
There are Windows 8 mobility drivers available from AMD:
https://www.amd.com/en/support/graphics/...
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
where can I get a copy of win.7 for free ?
さんによる
I need to up grade to win.10,
さんによる
Please help,wileyjack673@gmail.com ...
さんによる
Hi @jackwileyjr
I posted that 4 years ago. You are a bit late! But shop around. You either want a legitimate "Retail License" which can be transfered to another machine as long as you deactivate it on the old one. There are also legitimate one off licenses/keys, for $10 - $20 USA, which can't be transfered. Here is an example:
www.G2A.com
You will still need to download Windows on to a USB flash drive to make the installer. Rufus v4.40 does this nicely. Download and read the documentation.
You can run a limited Windows un-activated if you can put up with the nags.
さんによる
コメントを追加
To check what's on your computer go to start>control panel, on the top right of you screen your going to change to large icons, then look for the icon called system, there you'll find everything that is on your computer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hello people,i loved my dv 7,so i put win 8 on it ,i liked it so i went to win 10 then started having all kinds of problems with the mother board burning up,2 boards later i dont dare going to 10 again,im using win 7 and its fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SDalek さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 31
今までの合計 4,685
