software issue or charging problem
My iPhone 4s started having issues with the battery last month. ("Newly"installed before last xmas). I tried a "soft" recalibration by leaving it a long time to discharge and then charging it, but it never went beyond 1% according to the iphone, while having a good duration.
After a very long discharge, I started recharging it, and I wonder whether I screwed it by turning it off while it was rebooting. After that it never recharged...
I finally opened it to take a look, and I found a tiny smd (looks like an 01005 package) loose inside. I guess it is probably a resistor, although a can't make out any lettering on it. From what jessabethany said on an iphone5 thread, the phone should probably work even without this smd in place, but I wonder if it breaking off is connected with the charging problem. I don't have micro soldering tools, and cannot see yet where it came from (I don't see any obviously empty pads on the logic board). I have some pictures, and would highly appreciate any advice.
Update (05/30/2017)
Here's the best picture taken so far, and cannot spot anything missing. Can anyone help???
この質問は役に立ちましたか?
8 件のコメント
You cannot draw any correlations across device models. What is critical for one device may not be for another, or completely absent in a third. Post a picture of where you think this loose "resistor" fell off from. Some components are critical and their absence can kill a phone. Others are like your toes. You can loose one and still live normally. Awkward, but otherwise fine.
Rany さんによる
I haven't been able to spot where it could come from, and my links to the pic of the smd are not going through moderators...
but many thanks!
angelesdecara さんによる
angelesdecara, The link below may help you add pic's.
iFixitでの質問に画像を追加する方法
L Pfaff さんによる
Thanks a lot for your replies. I'll get on with it and let you know what I find. I'll add now the only pic I have of the ca. 1mm smd.
angelesdecara さんによる
You'll need to upload a high resolution image so that we can zoom in. Also, when you want someone (or more than one) to know that you have added information, use their @ username to notify them (mine is @refectio). For example, this new answer you just answered does not notify me, I just happened to see it because I bothered to dig a few pages deep.
Minho さんによる
3件以上のコメントを表示
