メインコンテンツにスキップ
The Venue 8 is a midrange Android tablet, released by Dell in 2013.
Where is the HDD located on a Venue 8
Disassembling a Venue 8 5120 for Recycling and I wanted to remove the HDD to destroy it and I cannot seem to figure out what part is the
HDD
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Tablets usually have an "HDD" soldered on to the board. Unfortunately, unless you identify the storage chips on the PCB, there isn't a physical "HDD." It is rare to find a replaceable/upgradable storage drive on a tablet.
More appropriately, it might as well be called an SSD, but still.
If you can boot it up and trigger a system reset so that it clears the onboard storage and returns to factory default, you shouldn't need to worry about it. Otherwise, take a stab at random chips and see which ones hold the data.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This image is from dell venue 8 pro.. but the chip is an BGA-153 on ailexpress. have not hear if anyone has upgrade it or not..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Denom Krall さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 1,739
