メインコンテンツにスキップ
Repair information and support for GE Profile Refrigerators.
60回答 すべてを表示
Why is my freezer not at 0°?
My refrigerator model is GE Profile side-by -side PS123SGPA BS. Digital temperature panel in refrigerator section has a freezer temperature reading that hovers in 24°-26° range. Noticed it was warm few days ago.
Any idea what I should check or will this require a technician before buying a new fridge?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
@ajultaylor what is the temperature in the fresh food (refrigerator)section?
さんによる
It defrosts occasionally. Check it at different times.
さんによる
Is there frost on the back of the freezer panel? If so , then the unit is not defrosting and would require replacing one or the following ... defrost thermostat , defrost heater and or control board
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@ajultaylor since we do not know yet what temperature your fresh food section is, follow the flowchart for whatever condition applies to your fridge. At this point I would think that the error is related to the main freezer thermistor, the damper or the control board. Let us know what you find out so we can further assist you.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Drew さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 36
今までの合計 1,773
