メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
I get NO SERVICE msg in my phone
i have a iphone 3G 8 GB. i am finding a problem with my phone, which is that my iphone gives NO SERVICE msg most of the time. When i put the same sim card in any other mobile i get good signal. i have tried a lot of things but nothing is working. what to do? please advise
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
6件の回答
最も参考になった回答
Have you tried a different sim card in your phone? If so and the problem still occurs, u might need to get a new antenna flex cable for your phone. If they do not sell on ifixit.com, try ebay.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have the same issue on the same iPhone.
Discovering on all around forums and internet that may be the baseband has been broken.
I have replaced the antenna assembly two times and I'm still getting the NO SERVICE msg.
So the issue is not linked on the antenna flex cable or antenna assembly.
Now I'm trying to get a new phone logic board that I hope to find.
I advice you to try this.
Step 1: Try to downgrade your FW to the 2.x version
Step 2: Modify your fw in order to install cydia
Step 3: Download FuzzyBaseband from cydia
Step 4: Try to downgrade your baseband
I hope you will get more luky then me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is your phone jailbroken?? i had this problem... it can simply be that too much stuff is being used, i dont know how it works but i just reset everything to look factory and my signal come back-
for a temporary fix, switch 3g off and then turn aeroplane mode on then off, will force the phone to search for signal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I mean that he tryed to open the iPhone assembly and after re-closing it he got this prob.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
In which case you have probably not connected ribbon number 5 correctly.
さんによる
コメントを追加
He probably has to ensure that no5 is plugged-in correctly, but in my issue I have re-plugged that cable so many times and each time the phone gave me the NOService msg.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same issue since i replaced my iphone 3g 8gb lcd and screen my phone fails to get signal except on 3g occassionally, it sometimes comes up with normal signal if left for a while but still doesnt make calls, and/or the call fails all the time. also wen i do get to make calls on the 3g people fail to hear me after about a minute or so......help! ive tryed everything! thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ashima さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,770
