メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
締切られた回答
My Computer recognize it as a camera
How can i change tha way my iPod is installed in my computer?? My laptop an any other computer recgnize it as a camera whenever i plug it to it... I want to use it as an external device such as a memory, just like my iPod does, i can xplore the folders in it, but im my iPhone i can see just the pictures. Plizz Help Me!!!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Connect you phone, go into My Computer
, Right-click on your phone and select properties. Click the events tab and then select "Take No Action". But it shouldn't affect your iTunes. If your phone is not recognized, then either Mobile Device Helper is not running or is corrupt. uninstall from Add/Remove programs and reinstall iTunes and you should be good to go.
Another quick check is to go into the control panel, Admin Tools, and services and see if Apple Mobile Device is running. If not right click it, go into properties and make sure it's set to automatic and then start it.
Also, you might want to look in the device Manager under USB and see if there is any ports that might be erroring.
Here is more info from Apple http://support.apple.com/kb/TS1495 ...good luck
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 3,871
