メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
Why won't my battery recharge?
My charger stopped recharging my acer c720 laptop. I got a replacement power cord but it won't charge. If I unplug it the system goes blank. As long as it is plugged in, the computer it works. I can't get into the back of it to see the internal battery. There was a puff of smoke from the back and that was it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Acer C720 Motherboard Replacement
You can basically follow that guide on how to open it, once in your on your own.
https://www.amazon.com/Acer-Chromebook-B...
There is the new part. The smoke isn't a good thing. It could mean that somthing fried. If the new battery doesnt work, return it and get a new chromebook as your chromebook is toast.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If you wanted to help this person, you'd try to locate what part burned out, test the motherboard to see if it's intact, see if another battery would work. Check to see if the battery poles were matched up correctly, or not--just that could fry a notebook.
さんによる
コメントを追加
回答を追加する
Carmen Leach さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 29
今までの合計 678
