メインコンテンツにスキップ
Samsung Galaxy S4はモデル番号i9505、13メガピクセルの背面カメラ、5インチ 1080ピクセルのディスプレイを備えています。
526回答 すべてを表示
nothing appear on screen , tried to replace the screen and still same
Hello
i got a galaxy s4 which is not turning on
i plugged the power supply to check if the motherboard is working , and i got a sign of Amperes meter of 0.25 and varying, which mean the motherboard is ok but the screen was not showing anything
then i tried to see if the problem were the cables , but they were fine , none of the copper terminals of the cable was damaged
after that i tried to replace the screen , but still the same problem , its not showing anything
is my method of checking is right ?
and what could be the problem now , did i miss somtihng ?
please help me to fix it
thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
try replacing the battery might resolve the issue.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
tried it , also the same problem
さんによる
try, changing the motherboard that may resolve the issue.
さんによる
コメントを追加
回答を追加する
Hesham Adwan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 44
