メインコンテンツにスキップ
My micro SD card isnt working and bearly reading.
i reformatted a micro SD card with my mac, but it failed halfway and is no longer readable by my tablet, my mac wont directly read it, but does detect its existence, and my windows installed it's drivers, and detected that it was a usb storage device, but i could not access it, it seemed to only appear sometimes, i cant see how to reformat it properly to fix it, it seems that device managers can see it but not do anything with it, while it wont appear to file explorer/finder, or terminal. just device managers.
is there any way to install new drivers or reformat it properly?
is it just trash at this point? it isnt hardware damage, just an improper format made it not properly readable.
the way i tried to find it with terminal was
"disk part", opened up the disk partition terminal, then typed in "list disk"
nothing, just mac seeing it, and windows knowing what it is but not being able to use it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
@magicalpamda, what do you see in Terminal when you type 'diskutil list'?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I have the same problem when I flash my SD card wrong. Just put it in a camera and format it with that. Then format format it with your mac.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
my wii didnt take it and my camera will just shut off if the card is in there
maybe a PS3?
im just going to see what and if things can format it
さんによる
@magicalpamda Do you have a sony camera? That should work.
A PS3 doesn't have a SD card slot.
さんによる
the camera didnt know what to do so it shut off
the wii didnt know how to use it
and the ps3 and xbox 360 both didnt even see the drive and try to format it.
my best bet is a PC.... i think the device's drivers might be totaled.
さんによる
You don't need drivers for an SD card. Besides, a PC doesn't do any better. All you need is a sony camera. If you have a friend with one ask them to format it for you. Just put the card in, turn the camera on and format it.
さんによる
@pccheese Launch edition Ps3 have a SD card slot under the flap in the front.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Tayo Fox さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 55
