メインコンテンツにスキップ
LeapFrog Leapster learning system, older model with stylus pen.
Where can I get my device repaired?
Can anyone PLEASE let me know where I can get my device repaired?!?!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
12 件のコメント
Hi,
What is the problem with your device?
さんによる
Yeah I got it for $7 at a goodwill. Just wanted to see if I could fix it. The main issue is that batteries were left in it that leaked over a long time...
さんによる
I remember when I had one of those.
さんによる
@ah1234 on here we try and help you fix your own device. You are empowered!
さんによる
Well lmk how?
さんによる
7件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
@ah1234 sounds like the battery contacts may have either been to destroyed by the alkalinity of the old batteires or just not making good contact with the rest of the Leapster. You can clean the contact with some vinegar on a cotton swab (may have to repeat this a couple of times depending on how bad they look). Once properly cleaned check to see if you have better results with new batteries. If not, then you will have to open the leapfrog. Try the instructions from here. Take plenty of picture while you do so. You need those to reassemble the device and/or make a guide for the rest of us by following these steps. you can also post those images with your question, by using this guide so we can see what you see.
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
My son's LeapPad 3 the screen keeps displaying that it needs to be updated buy a computer we try to update it and it did not work where can I take it to get it fixed
さんによる
コメントを追加
回答を追加する
A H さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 770
