メインコンテンツにスキップ
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
63回答 すべてを表示
Why does the screen flash when I try to turn the laptop on?
Sometimes when I press the power button the screen of my dell inspiron 1545 gives a short, bright flash like a strobe light. It's done it a couple of times before but always recovered and managed to boot but this time it's stuck doing it. I took the battery and HDD out and put them back in again, this didn't fix the problem. The LED on the charger is green and everything seems normal with that. The screen will flash with either power source; just battery or just charger
Is there any way to get it back up and running?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi,
Is the display 'normal' when you access the BIOS menu area by pressing F2 on boot?
If so can you boot into 'safe mode' and see if the display is normal as well?
さんによる
Unfortunately there's no boot whatsoever so I can't access the bios, there's only the strobe flash of the screen. To be honest I think it might be time for a replacement laptop
Thanks for the response
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Im having the same is issue, the solution is to change your battery
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
if this does not work, it may be a hardware issue; let me know my solution does not work
さんによる
The battery normally wouldnt cause this. One easy solution is to remove it and test it without the battery just plugged into the wall. If it works then its the battery, if it does the same thing, there is other issues
さんによる
コメントを追加
回答を追加する
lipase さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 237
