メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
152回答 すべてを表示
Rear Camera does not work after replacing broken glass screen
I replaced broken glass screen on my iPad2. Digitizer was working fine. The iPad functions well with clear glass but the rear camera is neither working nor recognised. Front camera works normal. What could have gone wrong?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You may have damaged the rear camera flex cable when removing the screen or reassembling. The camera is easy to remove once you have the screen off, iFixit has a guide. Check the cable carefully to see if there are any nicks or damage to the cable. You could also just try reseating the cable in case in came loose.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Well. I was hoping that I don't have to take the screen apart. Disassembling with broken glass screen is rather easy. However, if it has to be so then will do it over the weekend. Thanks! Will inform the results, once done.
さんによる
Hi David - I did all that you suggested. Everything with hardware seems to be in order but the rear camera does not work. Thinking that it could be software glitch, even reinstalled the iOs through iTunes but no success. May be that the camera itself has got damaged while repairing the glass. Thanks for your help.
さんによる
Yes, if you have reinstalled iOS, then your only other option is to replace the camera itself.
さんによる
コメントを追加
回答を追加する
Scooty Dams さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 76
