メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Why is my iPod touch freaking out?
My ipod touch is making a ''little box" around every app I touch and i have to double-tap for the app to start. It also won't let me scroll down on anything(ex. settings, safari pages, etc.)Another thing it has done is rarely let me get to my second page of apps. My ipod also shouts out everything I do so if I'm entering my passcode it shouts out the numbers of it, and a more annoying one is when my screen is locked...
In wrap up it has...
  1. 1: A little box around each thing I touch...
  2. 2: I have to double tap to get to the thing I want to get...
  3. 3: No scrolling down...
  4. 4: Rare access to my second page of apps...
  5. 5: Shouts out everything I type...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 18
11 件のコメント
Rachel, did you try to restore it under iTunes?
さんによる
it does all that stuff to mine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
さんによる
@kennedy, and what have you done about it? Have you tried the solution that I proposed in my original answer?
さんによる
it does it to me 2
さんによる
guys same case and im crying please help....how do i even scroll down in the settings to click accessibility?
さんによる
6件以上のコメントを表示
コメントを追加
6件の回答
ベストアンサー
Rachel is it possible that you have the accessibility options on. It does sound like it, at least most of your problems. Check out this link and see if that is familiar.http://www.apple.com/accessibility/itune... and here is how to manage it. http://support.apple.com/kb/ht3577 but these are just my 2cents and I may be way off:) good luck
このアンサーは役に立ちましたか?
スコア 15
18 件のコメント:
I love you. oldturkey03, I was literally about to cry because I didn't know how to fix it. Until the part telling me how to scroll so I could get to accessibility. So THANK YOU. :)
さんによる
it worked thanks alot..big help..
さんによる
U r welcome :-) good luck.
さんによる
OMG thank you sooo much! such a relif i thought i would have to take my ipod back O.O
さんによる
same!!!! its really anoyinng
さんによる
13件以上のコメントを表示
コメントを追加
triple tap the home button or go to settings >general>accessibility and TURN OFF voice over
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
That is what the links in the original answers are saying.....:-)
さんによる
How do you fix it
さんによる
How do you fix it now m hole screen turned black
さんによる
See Bryan's easy answer. This works, was easy to understand and is quick. I followed the apple support link into confusion and dismay, yet Bryan's took 10 seconds and a few double clicks. Cheers mate!
さんによる
コメントを追加
Rachel this is the voiceover in accessibility, you might have turned it on. I suggest you go to settings, then general, then accessibility, from there you would see the voice over, tap it. Then turn it off.
By the way, for you to do this, you need to scroll down which you cannot, so use three fingers simultaneously to scroll. I hope this solves your problem :)
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thank you so so so much!! I was going crazy trying to figure this out today! Your post saved me some grey hair!
さんによる
i had the same thing happen to me and the 3 finger thing actually works so thanks
さんによる
Brilliant thanks for the info. My daughter had the same thing. I thought we were going to have to replace it. It took a couple of tries to get the three finger scroll thing to work but it did. Working perfectly now. Thank you.
さんによる
コメントを追加
Go to settings, and click on genaral-accesibility-Turn off the voice over!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
how do i click accessibility if I cant scroll down? How do I scroll down?
さんによる
コメントを追加
Sync It To iTunes && Click Configure Universal Access..
Then Where It Says Speak Auto Text Click That Box Until It DOES NOT Have A Box Anymore. Then Click Apply. If Apply Isn't Optional Then I Guess Press Sync.
Hope I Helped.
I Had The Same Problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
go to settings if not able to slide over to it use three fingers to swipe go to general three fingers scroll down to accessibility and turn voice over off by double tapping
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rachel さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 28
今までの合計 60,309
