メインコンテンツにスキップ
Repair information for the Gaggia Classic Espresso Machine. Can also be helpful for repairing a Philips or Saeco espresso machine.
20回答 すべてを表示
Steamer no longer works
Following what sounded like a burst of water falling on a hot surface inside the machine, the steamer worked briefly then gave up entirely: no water, no steam, no sound. The coffee portion of the program still works fine. Does this sound like a failed part that can easily be replaced?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If you not descale the unit frequently, a thick layer of scale is created on the walls of the boiler.
Let’s say you never did descale the unit for like 2 years, and suddently decide to descale it, the thick scale build will unstuck from the walls forming big chips of scale on the buttom of the boiler, when you opening the steam knob, some chips may get stuck into the pipe/valve, reducing the pressure.
You should open dismantle the compleet valve and maybe keep it on a descale solution for some time to resolve the p problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
DCA さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 144
