メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
What causes my MacBook to power off and not turn back on?
I spilled a glass of tap water on my laptop, I immediately powered off and did a water damage treatment but now when I shut the laptop instead of going to sleep it powers off and won't reboot until I disconnect the battery. All the functions work fine. This is the only issue I'm having. Please help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You probably shorted out the power on button. By disconnection the mag-safe and battery then plugging back in you are causing a spontaneous reboot, bypassing the power on button.
You can say thank G-d it powers up and maybe I'll just put it to sleep when not in use. Or you can replace the keyboard or uppercase. Do the rest of the keys work?
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Yes, the rest of the keyboard works the up arrow occasionally randomly stays stuck on though :(
さんによる
@northnaplesdpf I was trying to move your comment to this position and the system deleted it and gave you a negative 100 points. This is a system error and we'll get it corrected by Monday @evan
さんによる
コメントを追加
回答を追加する
lee burnett さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 63
